bigmanjbmopar
Newb with a view
Anyone have experience with the switch going bad? or your reverse lights not working due to the switch or wiring? If so what was the fix? I got strange readings from the volt meter at the starter relay and fire wall connectors.
69 has 3 wires going to the switch one is from the one side of the starter relay a neg and another getting pos from the radio connector and the third going to the back up lamps can't seem to get any volts out to the lamps but get it to the switch from the firewall but loose it suddenly once in reverse?
thanks
thanks
