96Formula6sp
Hey everyone after about 45 minutes of looking online I can't get a straight answer. We are swapping our 1972 Coronet to a A833 Overdrive Transmission from a Dodge Pickup Truck. We are in need of a bellhousing and one showed up on the local craigslist with the part number of 3515734. Its also only $150. I checked and this is for the small 4.354 bearing retainer. And it is also for 72-74 E body and 67-71 A body. Now I know off the bat that it will not bolt up but here are my questions.
Question #1
Could we have a machine shop drill the hole out from the 4.354 to fit out 5.125 bearing retainer? It looks common on the 4.807 to 5.125 but not 4.354 to 5.125. Is there a reason for this?
Question #2
If we used the above bellhousing on a 71-74 B-Body what clutch linkage stuff would we need. Could we just bolt B-body units into that bellhousing. Or would this require a random assortment of parts to fit. What do overdrive people do?
Question #2.5
If we get a truck bellhousing will it be able to work on a b-body? It will bolt up to the engine but what about linkage stuff?
Coming from GM stuff where the reuse everything and make it simple. So far I have got somewhat confused at mopar. Mainly not getting straight answers while searching. Hopefully I can get an answer by the weekend so we can pick up the bellhousing if it will work.
Question #1
Question #2
Question #2.5
