a833 install
jeff deakins
1:00 PM
daphne alabama
Installing 4 speed in 1966 coronet three on tree.Will i need to install shifting tunnel in floor or will it fit with standard tunnel
Thanks in advance
I'm no expert here..... I think it will "fit", but you won't have a place to install a shifter.
You’ll need to cut the tunnel and install the 4 speed tunnel housing
The only reason the 3-on-the-tree doesn't have it is because there's no shifter down there. to fit the bracket, box, and rods you need the hump.
