AAW mega fuses - mounting location suggestions
erw312
5:31 PM
Akron,Oh
Installing American Autowire engine harness. Any suggestions for mounting location of the mega fuses? This is for '68 Roadrunner. Thanks.
Yes, read the manual many times. No real suggestions other than in engine compartment close to battery source.
That is the best place for it to limit the amount of wire before the fuse in case of a fire before the fuse is blown.
Understand - I'm thinking of making a bracket and mounting under the voltage regulator.
You can find different sizes of plastic, gasketed boxes on Amazon that could be used to conceal relays, fuses, switches, etc. It will clean up such device appearances.
Mike
