AC delete 72' Satellite
docepc
9:44 AM
new jersey
I'm looking to delete my A/C from my 72' Satellite. I removed all lines, condenser and all that's left is the compressor. What do you I need to order if I remove the compressor...different bracket's, belts, pulleys? Thanks for the help.
Just FYI-
Almost every year brackets and pulleys are different.
...and almost every year AC and non-AC brackets and pulleys are different.
Be advised.
Yes brackets and pulleys need to be swapped out when you remove the compressor. You can use the same alternator but if it has two grooves on the pulley you will use only one now. All the non-AC brackets and pulleys are available new from various vendors.
PM me if you still have the lines. I need to mock up my old system to a new sander. Would help me out.
