Yatzee
Calling on all creative and knowledgeable members for relocation of my power steering pump and alternator from the original positions. The pump is a Sag, sits low and the pressure line interferes with the right lower mount. Has any one moved the acc's on a big block 400 and how can it be done? What brackets did you use? Where did you mount them? I have both 3 and four groove crank pulley's. Did you use an idler to clear the water pump? This is brain storming at it's best and I know it's possible with out spending a fortune to move the accessories to other locations. Just haven't figured it out yet. All suggestions are appreciated. Is there a better PS pump than a large Saginaw that can be used in tight places but put out the higher pressures for my steering box and hydro boost braking system?
