bigmanjbmopar
Newb with a view
So we have fixed strut rods from the factory, several vendors mostly PST sell the adjustable strut rod. What is the advantages if any over stock? Should you use them with a stock suspension as an improvement feature or do you need to get all the other stuff like tubular upper a arms and LCA stiffening plates etc? Also what exactly is the adjustment you can do on these and has anyone here used these and can speak to these?
Description from PST -
Dramatically improve the cornering performance, traction, and steering response of your muscle car with PST's new Adjustable Strut Rods! Designed to positively locate the lower arm, these strut rods improve responsiveness and driver control. The adjustable design features 5/8" high articulation rod ends, CNC bent brackets, and lightweight TIG welded 7/8" tubing. Finished in a lustrous nickel-plated finish, these strut rods even look great standing still and push your performance to new levels.
Description from RMS -
Our tubular strut rods use a special pivot point to eliminate the flexing and bind of traditional bushings.The result is friction-free motion vertically, and no fore/aft flexing of the lower control arm, which causes hard to control dynamic alignment changes. These alignment changes cause the "wandering feeling" that's so common in older cars. Freeing up vertical motion allows faster weight transfer on the strip and a smoother ride on the street.
