Ricks427
Aeromotive Regulator
Aeromotive "SS" (Street/Strip) Series pressure regulators allow high fuel flow volume with very little pressure creep. They are appropriate for use on street or racing vehicles.
This model can be set to between 5 and 12 psi. Adjusting requires an accurate fuel pressure gauge (sold separately). The "deadhead" regulator type does not require a bypass return to the tank.
There is one 3/8 NPT inlet port (bottom) and two 3/8 NPT outlet ports (side) to aid the connection of multiple carbs (single carburetor applications should plug one of the outlet ports). A separate 1/8 NPT port (plugged from the factory) is also provided for easy installation of a fuel pressure gauge (sold separately).
Compatible with gasoline, alcohol blends to E-85, and diesel fuel.
$75 + the trip. Will accept Paypal if you pay the fee.
