troublemaker
So guys I know you answer this a thousand times a year, please humor me. My 1970, 440 Roadrunner has a 22" Radiator. I just upgraded to ECP 2 ROW 1" tube Aluminum, FloKooler pump, Miloden full flow 185 stat and new shroud w/stock fan and new fanclutch assembly. The engine has no miles just break in miles (under 100) stock to mild rebuild. stock heads, 30 over, mild cam, dual quads, headers, normal compression. Timing is at 7 deg. . While at idle the car heats up to about 195 to 200. Gauges are all rebuilt and calibrated. This is after idling for about 40 minutes on a 75 degree day. I would like to get this down but don't want to add a pusher. Do u think going to a mechanical fan would help? Or any suggestions
Thanx in advance
Thanx in advance
