alignment specs
62polara500
3:59 PM
Willcox AZ
does anyone know what the specs are for a front end alignment on a 1962 Dodge Polara 500?
Manual Steering: Caster = 0 to -1 Desired = -1/2 Camber = Left +1/2 Right +1/4
Toe- in = 1/8" Toe-out on turns degrees = Outer wheel 18, Inner wheel 20
Power Steering: Caster = +1/4 to +1 1/4 Desired = +3/4 Camber, toe-in & toe-out are the same as the manual specs
Source - 1967 Motors Auto Repair Manual
I'm getting my 62 Plymouth aligned tomorrow and was going to write down these specs - but I don't understand what's written here. The run together with = signs is confusing. Can someone help translate??? Only need the manual steering part.
