Mike Gaines
- 12:32 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
All Motor parts are for big block Mopar....Wedge
PARTS JUST CAME OFF CAR....HAVE NOT BEEN LAYING AROUND FOR A LONG TIME. REASON FOR SELLING....UPGRADED TO INDY HEADS, INTAKE, CARB ETC AND CAL TRACS.
GOOD BUY ON SOLID PARTS.
1) set (pair) of Iron Heads...Ported and intakes flow 267 exhaust 216 @ .600...2.19/1.88 valves complete with Crane (up to .580 lift spring (#99893), retainers (#99944), locks (#99097), etc. ready to go on...complete with set of Head bolts ... and a pair of Fel Pro # 1009 Head Gaskets. $500 (port job alone was $500 plus the big valve installation)
2) Set of 16 Smith Bros Pushrods for solid lifter cam. $50
3) Set of 16 Crane Gold Roller tip Rockers complete with shafts & Clamps,ready to bolt on. $225
4) Set of Fabricated Aluminum Valve Covers with the super deluxe "screw on" Moroso Breathers.$75 (Breathers alone were $40 each)
5)Chrysler M-1 intake (complete with brand new FelPro Bathtub metal valley tray and opposing gasket set. $180
6) Holley 950 HP Race Carb $450 ($900 at summit)
7) 50cc Holley pump conversion kit. $30
8) Set (pair) of genuine Mopar Super Stock Springs...came off my 66 Coronet...so fitment is for whatever other models they fit. 20" from from front eye hanger bolt to Ubolt center...true Mopar Super Stock Spring setup. $175 Pair
8a) Pair of Mancini Racing shock plates with Shock studs (does not include the ubolts) $75 ($120 at Mancini)
9) Mancini Adjustable Pinion Snubber. $50
10) K&N large Air Cleaner..all freshened up with new K&N filter lube. $70
11) 3 brand new sets of Autolite Spark Plugs for those iron heads above. Correct heat range $30 for all 3 sets.
12) Custom Ground Camshaft and solid lifter (non-roller) set. RPM range: 3700-6600. .570 lift Intake C/L 104.1 Duration 265...compares closely to Comp Cam # 23-362-5) $125
Parts are located in zip 93601 near Fresno CA
