All parts must go
truetriplex
7:30 PM
Ball Ground, GA
Feedback: 3 / 0 / 0
After 30+ years of Mopar restoration, it is time to retire. I am in the process of compiling a list of items that should be of use to some of you. Mostly B body, some E body, and many convertible pieces. I have HP motors, date coded carbs/distributors/manifolds/alternators, etc. Remember, if you don’t see it, you may want to ask. And you are free to throw me an offer too.
Many items are NEW still in packaging and are so listed. There may be some shelf wear. For reference purposes I have tried to list part numbers (mostly Year One, Mopar, OR OTHER). Items may NOT be from these suppliers but are always top quality that I used in high end restoration. Again, I do this for reference only. You can check the YO web site to see if this is the item you need. Price does not include shipping or handling.
BODY/SHEET METAL/EXTERIOR PARTS
67 Plymouth GTX/Sport Satellite Tail panel $85
69 Plymouth rear quarter extension driver side $35
69 GTX/SPORT SATELLITE ORIGINAL GRILL fully restored $650
69-70 B body Air grabber to hood screw clip set (NEW) (reference to SR181) $40
69 Plymouth hood scoops, 2 sets (reference to (HRR68I) one set has 1 broken stud $100/set & $75 (broken)/set
68-70 B body vinyl top trim clips $5
68-70 B-Body 1 set 15b wiper arms (good condition) no blades $40
68-70 quarter window Plymouth Door glass B body ORIGINAL $75/ea
68-70 Charger rear window ORIGINAL $200
68-70 B-Body Rear footwell floor pan from AMD NEW (reference to FW68RH) $80
70 Plymouth road runner PASSENGER SIDE headlight bezel (reference to HLM8RH) $50
71 B body KF101 spoiler mounting bracket set (reference to KF101) $25
SUSPENSION
66-72 A/B body Sway bar end link set (NEW in package) $15
66-72 B body Upper control arm bumpers (NEW in bag) (reference to FD5204) $7.50 EACH
Torsion bars 776-777 .88
Torsion bars 780-781 .92
GASKETS/WEATHER-STRIPING/MOLDINGS
69 Plymouth quarter extension gasket 2 sets $15/pr (each set)
68-70 B body – molded door ends (ALP7001 NEW in bag) (reference to FR474) $30
66-70 B body 151329 Fire wall gasket kit W/AC (NEW in bag) x2 (reference to XH89) $27/EA
67 Plymouth B body BBE6767TL101 tail light gasket set $25
68 Charger rear tail light chrome trim driver’s side LARGE PIECE NEW chrome (reference to TLT68)
$45
68-70 AC box Heater bypass valve “h” valve O.E.M. $100
66-67 HLS016 Plymouth headlight seal NEW (reference to SF1) $35
68-70 B body HS 66 firewall AC gasket set (NEW in bag) (reference to XH99) $30
68-70 B body CH2077 hood to cowl (NEW in bag) (reference to CC2077) $15
68-70 B body FFRT010 Front Fender Rear Top Splash Seals (NEW in bag) $18
INTERIOR
69 GTX door trim emblems $50 each
68-70 B body POST CAR headliner side trim pieces $50
68-70 B body 2 sets coat hooks $10/set
66-68 Shift knob (spring + button) fresh chrome (reference to SK669) $50
68-69 Used button gear shift $5
Center console slider NEW (reference to ACR670) $15
67 Plymouth window cranks (set) NEW in bag with spacers (reference to MH67) $45
69-70 RR interior trim screw set (NEW in bag) (reference to SK170) $35
68-70 charger (DF2) door lock Ferrell (reference to FW817) $12
68-70 B body Upper Seat belt retainers shoulder harness (reference to SBC6P) $45
58-70 Bench seat hinge covers BLACK (NEW in bag) (reference to W668) $40
Clutch return spring (4 speed Assembly) $25
69 Charger sun visor w/ rod (1 only) $40
68-74 window cranks set (NEW in box) w/ spacer (reference to BN17) (2) $25
66-67 B Body Package tray jute NEW (reference to PJV66) $15
68-70 B body inner door pulls ATP 146 (NEW in box) (reference to DP68) $30
68-70 B body Arm rest base 3-9 1/2” 4-11” chromed and ready $45
68-70 B body inside header trim panel clip $15
B body – 6 way seat release/ knobs/ 2210SK (NEW in package) $35
Buddy seat with brackets $45 $85
69 Plymouth Rear seat emblem (ORIGINAL) with retainer $80
68 Charger Rear seat back (Upper only) $80 OBO
DASH
68-70 ORIGINAL newly re-coned 4 X 10 dash speakers $100
68-70 Dash speaker mounting plates $45
69-71 B/C and 71-74 E body AC heater control units 3895790 x2 (reference to FD5790) $80
68-69 Plymouth AC center vent – mounting bracket $45
68-69 B body Tach/clock block out plate non rallye $25
68-70 AC center vent Extremely nice $60
AC vent w/o vanes $10
68-70 B body Speaker hold down plate $20
68 AC heater control DASH switch w/ vacuum assembly $85
69 B Body 3 sets carb air cables ORIGINAL (reference to AO191) $60/ ea
67 upper dash pad core only $40
68 upper dash pad core only $40
66 Plymouth B body instrument cluster $85
68 Charger rear defrost plate NEW $40
68-69 B body Plymouth lower dash pad BLACK for A/C $125
ELECTRICAL
69 Plymouth B body under dash wiring harness (reference to HU271B) $350
56-71 Ballast resistor FR590A (NEW in box) from year one (reference to FR590A) $30
Points 209B244 (NEW in BOX)
Chrysler condenser 34206 (NEW in box) x4
Neutral safety switch – 3pin for 727 trans (x2) (NEW in BOX)
Flasher (NEW in box) year one 6503N 5
Starter relay – auto (NEW in box) 10
TRIM/DECALS/MOLDINGS/EMBLEMS/RUBBER GOODS/CHROME ITEMS
1969 Plymouth 440 hood callouts NEW (4) $40/each
70-71 Plymouth 440 – 6 air cleaner decal (70) NEW in package (reference to AC101) $5
69 GTX tail light bezel drivers side ORIGINAL NOT REPRODUCTION excellent $150
69 GTX tail light lenses – 3 sets (ORIGINAL) $120/set
68-71 GTX – quarter panel emblems (NEW) $40
69 GTX grill emblem – (2) NEW (reference to VC126) $40
bulbs for fender bullet lights (NEW) $3/ea
68-74 A/B/E Body Gas tank grommet x2 (reference to FD4182) $12
Antenna bezel (NEW in bag) (reference to J239S) $20
66-69 B BODY Hemi air cleaner decal (reference to AC 117) NEW $15
67- Plymouth Hood to radiator seal NEW (reference to FW935) $30
69-70 – B body front bumper guards (reference to KJ232) $70
MECHANICAL/ENGINE and ENGINE COMPARTMENT/DRIVE TRAIN
68-70 hood hinges $85
69 variable (3 speed) wiper motor 2983116 342 9 date code $100
69 Alternator 2095192 no pulley $45
69 Plymouth hood scoop insert plates $40
70-71 big block VC1 pvc value grommet breath (NEW in bag) x2 (reference to GR3447) $20
68-70 B body metal Hood pad retainers set (reference to J67) $32
Mopar master cylinder core
Dual alternator pulley $20
66-69 Negative battery cables 2ea 944 RT (NEW in bag) $30
70-72 ABE Battery retainer (no bolts) (reference to MR628) $12
70-75 ABE Battery hold down with J bolts (reference to MR627) $25
66-67 B Body bumper kit body BBK1 (NEW in bag) (reference to BPK7) $22
69-71 440-6 coil mounting bracket (Reference A0141B) $48
DISTRIBUTORS
2875982- IBS-4017A dated 45 9 EXCELLENT condition (dual point 6 pack) for a/t $600
2642727 for 67 383 both $75
2642730 for 67 440-4 both $75
2444261 for 64 361-2 / 383-2 both $50
3656763 for 73-74 318-2 both $50
2875334 for 68 273-2 both $50
2875358 for 68 383-4 a/t $75
Mallory YL-578-HP Dual point $75
Mallory 2557801 dual point for RB $75
4091140 (R0212134) for 81-83 $50
8 ¾ pinion snubber $30
68-70 B body Hood hinges $65
68-70 B body Gas tank lock ring NEW (reference to FD30095) $10
Filter fuel sock unit 3-3/8 1-5/16 (NEW) (reference to BG923 AND BG924) $13
66-70 AC vent hose BY PASS (reference to MT114) ($22)
68-70 B body USK02 under hood strap kit (reference to USK2) $14
68-70 B body A body Heater hose bracket fender mount big block (reference to AO336) $20
Drain cowl flap (NEW IN BAG) RP 900-A $4
62-68 Radiator core support anti-freeze decal (NEW)
J- bolts battery (reference to HD1) $2
CONVERTIBLE
68-79 B body convertible pump motor cover $100
63-65 B Body convertible 8 pc cat whiskers (reference to KG131) $60
68-70 B body convertible stainless windshield trim $150
68-70 B Body Convertible header corner for inside front windshield $30
68-70 B body convertible rear panel inserts-2 sets available (1 piece with chrome trim) $80/SET
68-70 B body Quarter window seal convert. CH 1023 (NEW in bag) $10
66-70 B body convert windshield gasket VWS 2704 NEW (reference to WCRD671) $75
68-70 convertible top Switch plate $35
Hi there,
What is the buddy seat and bracket out of. I am looking for one to fit in a '72 roadrunner. If it is the right year can you give an indication of condition or a photo and would you send it to Australia @ my expense.
Cheers
Adrian
Hi there,
Cheers
Adrian
This came out of a 68 Charger. and yes I will ship to Australia
Can you pm me on your 66 b-body coronet parts
All my early (66) parts are gone.
Hello,
I am looking for a pair of defrost vents for a 67 B Body (GTX).
Please PM if you have some to sell.
Thanks,
Zancat
I am looking for 67 coronet parts, specifically all weatherstripping, interior, and grill parts. Others could come in handy too though. Could you PM me anything for that?
Hello,
Thanks,
Zancat
Sorry, none available
Hello,
Thanks,
Zancat
All exterior trim is gone. I will check on weather striping and let you know
SUSPENSION
$45
INTERIOR
DASH
ELECTRICAL
DISTRIBUTORS
CONVERTIBLE
Do you have any parts left for a 69 GTX?
Do you have a hood to bumper seal for a 70 charger? I've heard that it mounts to some kind of metal support so need that as well if you have it. Mine was missing when I bought it so not sure of all the pieces to it.
I am not exactly sure what you need. It almost sounds like the hood to radiator seal. If that is the item, then yes I do have one. Do you have a picture of the area where you are missing the item? If so, could you PM me and I will see if I can help you out.
what condition are 69 gtx taillite bezels? could you send pics. do you have a trunk finish panel?
