Alteration kmember
KRYLONKILLER
12:47 PM
PHILLY PA
I have a 65 coronet ,has anyone used one of these kmember ,on their 62-65 b-body,if so any info would appreciated
I have one on my 64 Polara. What do you want to know? There are benefits and drawbacks. Overall I'm happy with it.
i have one on my 64 polara. What do you want to know? There are benefits and drawbacks. Overall i'm happy with it.
which one did u go with ,n how much fabricating did u have to do ,n how much,any pics
I went with Reilly Motorsports AlterKtion (which is what I think you are referring to). The original. There are a lot of copies out there, some bad some good. I think I paid around $3500 around 8 years ago.
I had to do absolutely zero fabricating (unless you count drilling four holes fabrication). It really is a bolt on deal. The hardest part was getting the damned roll pin out of the steering shaft coupler. It was a lot harder than it should have been.
I'll post some pics a little later as I'm at work.
Originally got the manual rack, then switched to power steering because it was just too much of a bear to park.
Positives:
  • Headers drop in. No steering box or torsion bars in the way
  • Tons of room to run different oil pans
  • Corrected suspension and steering geometry - and you can run up to something like 7 degrees of caster.
  • Lighter than stock K-frame
  • Strong. I mean strong. Originally designed for drag racing and made to come crashing down off wheel stands.
  • Adjustable ride height
  • Air ride available.
Negatives
  • Increased turning circle
  • Coilovers have less travel than stock suspension
  • Anything under a 17" wheel and you have to watch your backspacing or it will hit the tie-rods. 14-16" rims must have a max backspace of 3.25"
That is one nice Polara. Good photos of the Kframe swap. Very interesting.
