aluminum wheels help please?
bzizzi
1:41 PM
connecticut
Hey,
does anyone know of where to get 15x7 and 15x8 polished slotted aluminum mags? I managed to get a set from Stockton wheels for my roadrunner right before they stopped making that size and now I need to find another set for my Superbee. Does anyone have them? 5 bolt pattern for a 1969 Superbee 15x7 front and 15x8 rear.
thanks,
Blake
Long live the Mopar!
I polished a set and just kept them waxed. Clear coat gets nicked up stuff. Used the Mothers polish on them....good stuff.
kinda a rookie question but.. my car has drum brakes now im assuming are 5 4 1/2 bolt pattern i am planning on buying a disc conversion kit what size bolt patterns do mopars have?
Depends...some had 5 on 4 1/2 while others had 5 on 4. My `70 Duster 340 had 5 on 4s while my `66 Belvedere II has 5 on 4 1/2. What vehicle, engine and trans combo can determine what you likely have.
Measure from the outside of one wheel stud (lug nuts off) to the center of one of the studs across from it. Easy.
It will measure either 4 or 4.5 inches. If its 5", you have a 1/2 ton truck axle, probably a 9 1/4" (could be a Ford 9" or IH Dana 44, too) If its 4 3/4", you have a GM axle and should sell it to a Chevy-guy.
Ebay! The trick is to look where others dont look!!
I found these 15x10 in OZ and the 15x3.5s in the USA. Lov'n the slots!
cheers Dave
