Acworld34
Hi Everyone so i just started doing the rewire to my car after getting a quote for $4K just for labor.
Notes:
1. definitely not plug and play. The instructions are confusing and not well written.
2. For the heating/AC system I had to use part of the old wiring and i am hoping it will work once i get everything hooked up. It should tell you if you are using old wiring and what parts are needed. I tried to take pictures of the old wiring before i took it out and when i figured it out that i still needed the old wiring i tried hooking the wires back up underneath the core but i am afraid that i have mixed up the wires.....for example :In the case of the bottom of the heating core it had two wires and brown and blue one... don't know if i hooked them back up correctly. 2nd pic
3. definitely need a wiring diagram of your specific car to figure this out.
issues: The horn relay is something i still am not able to figure out even from the instructions and wiring diagram (i bought this wiring diagram separately). The AA kit states plug into the horn relay. but i didn't know if this is a old part or i was trying to find where in the car is the actual plug for it. Does anyone have a pic of the horn relay? Resolved...a new Horn relay came with the KIT...didn't realize it.
door jamb switches are a different model. one plug from AA and two clips are the actual ones in the car. I ordered new switches and they were too small for my car.
Notes:
