wsutard
Recently my voltage regulator took a dump and caused an over charging situation that melted my alternator to ammeter wire inside the cab. This has given me an "excuse" to rewire the engine bay and upsize the alternator wire to 8ga.
As part of this rewire I am thinking of doing a "partial ammeter bypass". What I mean by this is I want to do the MAD Electric Ammeter Bypass but instead of disconnecting the Ammeter and splicing together the red and black, I want to run new wires to the Ammeter and use it to power the factory harness.
Here is the scenario followed by a picture. I will run my alternator wire directly to the bat + on the starter relay. I will also run two new wires from the bat + on the relay to each side of the Ammeter. I will keep the factory connections at the Ammeter so the harness will be powered.
I want to do this for two reasons. 1. I don't want to splice into the factory harness again due to lack of splicable wire and creating another weak spot. 2. I cant get behind the Ammeter to create a proper splice via the MAD Electrical directions.
Last summer I had the cluster refreshed and an upgraded Ammeter installed. According to the company who installed the Ammeter, it is far superior to the original and can handle much larger loads.
Thoughts, questions, clarifications?
