Rusty knuckles
Looking for a little guidance here and see if I'm missing something.
Ran the autocross today in my 69 charger with a basically stock 383. After a couple hard runs as I'm pulling back into the pit I hear distinct lifter rattle. I can get it to go away by essentially letting the engine cool off. It did this in the last autocross too. I tend to have about 15-20psi oil pressure at idle when warm and my thought was that wasn't enough when I go from idle to Hammering the **** out of it. So while I'm staged I've tried revving the engine to about 2000 to get my oil pressure up a bit into the high 30s or low 40s. This sometimes helps, sometimes not. Cooling off the engine always helps, like between heats. And oil pressure is good otherwise. Ran about 45-50psi cruising home at 3k.
I don't think I've hurt the engine as the tick goes away and I've made several runs coming in to hear clack clack clack. My oil level is good and I'm running 10w-30. I'm thinking I need heavier weight oil. Am I missing something? Would a bigger oil pan be necessary?
