Bruzilla
I didn't want to distract from the fresh air 73-74 hood string with this idea, so I'm starting a new string. I have often wondered what the benefit would be of using two fresh air lines running from the high-beam lamp openings to a closed, double-snorkel air cleaner, and installing one of those NASCAR inline brake cooling fans into each hose. The fans have three or four-inch diameters and move anywhere from 150 CFM to 350 CFM.
So, suppose you have two of the 350 CFM fans mounted inline with hoses to a closed air cleaner or air box. You hit the gas, turn on the fans, and have 700 CFM of air flowing in. What would the benefit or negative impact be? Any ideas?
