jogirob
I'm getting door sag.
I took a look at the door hinge situation and it looks like both ends of top and bottom pins are peened and the top hinge is facing the other direction so the pin is completely blocked from getting a saw on it. Is removing the door and sawing the pins in half the only way of replacing these? Will I have to remove the fender? How does one shim the hinge?
