Any SMR tranny help?
cjanicke
8:56 PM
Kansas
We are putting a 727 together using the SMR component kit. The instructions call for a brass thrust washer to be used between the two shafts and it should be included with our kit. We have the pro sportsman kit. There was no brass washer to be found. There is what appears to be a thrust washer on the back side of the input shaft. It has three tabs on it that hold it in place. Does anyone know if this is used instead of the brass washer or do I need both? SMR is on summer break right now until next week, or I would call them. We wanted to get car going this week.
Did you ever figure this out? I don't have any tech advice for you. I was just looking up info on the forum about these guys. They look like they make some pretty kick *** stuff.
