Performance 101 ; 1st & foremost have the bottom end ballanced with what ever hardware, rods, pistons, converter, balancer, so the bottom end won't beat itself up, make sure to resize the rods @ a minimum & use new performance hardware... then equally as important, 1a get some "good heads" or spend about the same money & have yours gone thru & ported, especially in the pockets, biggest single item you will make power with, or won't with out a good set of heads, on a Mopar RB Wedge, the heads are a big choke point {use good high quality head gaskets}... if you use the stock cast iron heads, get a good set of new S/S valves & a multi angle racing/performance valve job... get a proper size style cam, valve springs, retainers, locks, shafts, rockers & hold downs, suited for your goal/intended usage or driving habits, especially if the majority of driving will be on the street... if you need more converter because of camshaft & gear choices, than get a higher stall speed converter too, it's allot more than the just engine, the whole car needs to work together... camshaft lift doesn't really hamper you much {to an extent up-to 0.520" gross lift with stock valve-train, valve guides & non-adjustable stamped steel rockers} IMHFO it's too much duration on a street/strip combo that will hurt your overall combo, make the car really temperamental on the street... a properly suited & size fuel system, fuel pump & fuel lines {3/8" or #6 A/N minimum}, min. 3/8" fuel pick-up sending unit in the fuel tank, an adjustable fuel regulator is a good idea if you go with a high pressure fuel pump & use a proper sized carb {the Holley 750 DP is a great carb, tuned properly}, the Edelbrock Torker is a decent all around intake manifold, not ideal maybe but will work fine... Get a K&N or other gauze type free flowing air filter... get a se of 1-7/8" headers not some $99 cheapos that will drive you nuts getting to plugs & burning up plug wires, don't go to big on the tube size either... get a 2-1/2"-3" mandrel bent exhaust system, with an X or H-Pipe installed in the proper location, with free flowing mufflers... get a good quality oil pan with more capacity than the stock ones & use a windage tray {not too deep of a pan like 6-7qt. & 7" deep max, if your going to street drive it allot} & get a quality HV oil pump too, don't use a worn out oil pump, use a good quality oil & oil filter, not some $0.99 cent POS... get a good electronic ignition system & Orange or Chrome box CEI-ECU, get a hotter coil, use with low ohm resistance spark plug wires, to match the hotter ignition... a good properly sized radiator & cooling system is a must, performance mods have a tendency to create allot more heat, when you make more compression & more power burning more fuel higher BTU's is the results, get a better than stock water pump to move more fluid thru the cooling system... the pistons & rings need to be chosen for your intended usage also, don't bore the block anymore than you have to, use good tri-metal bearings with quality new rod bolts & hardware, not the stock weak, bolts, washers, nuts/hardware {don't skimp here}... if you do these simple basic things, no mater the combo, it will be a good performing & longer lasting 440 combo... your cylinder head & camshaft choice, will probably be the most important choice in your engine combo... good luck & happy Moparing, doing right the 1st time, it's not cheap, save a little longer & do it right, spend the money in the correct places... but it's far cheaper than doing, it all over again because your were a cheapskate the 1st time around...
