your MoPar 'man card' is safe
you can heat the bearing in an oven
(or use a torch if careful) to like 220*- 250*ish
they will expand some to fit 'more easily' on the shafts
less sanding & grinding or forcing them on
if you don't have a press especially
you can use cold compressed air, a cold rag in the freezer
wrap it, if cold enough to cool down
(or put the shafts in the freezer) if still accessible
or N2O/Nitrous Oxide to "shrink"
the shaft the bearing are going over
I didn't do a Ford top-loader, not for a long time now
but;
I just did a Borge Warner T-17 3 speed top-loader & Atlas overdrive
in a 68 CJ5 Jeep/Kaiser, I got a blown-up photo off the -www-
& I winged it
make sure to get "all the proper seals & gaskets",
silicone or just 'make a gasket' isn't long term & they will leak
ask me how I know, been there done that
my neighbor painted it black (it's his Jeep)
he has since taken all the black off after we had to reseal the whole thing
after his uncle just "rebuilt it" with silicone & 'make a gasket' sealers
