themechanic
Oklahoma is OK
- 9:20 PM
- Nov 11, 2012
- Moore, Oklahoma
The TCI® 4x Four-Speed™Auto Transmission series allows the use of a popular 4L80E or 700R4 transmission with non-GM performance applications. Both the 4L80E-based and 700R4-based versions of the 4x Four-Speed™feature an SFI-spec adapter bellhousing for easy installation of the transmission behind a Small or Big Block Ford, Ford Modular, Small or Big Block Chrysler, Gen III Hemi, Buick, Pontiac, Oldsmobile or GM engine.
4X Four-Speed Non-Electronic 700R4-Based Transmission - 750 HP
The fully mechanical 4x Four-Speed Auto Transmission, non-electronic 700R4-based is designed with street rodders in mind. Application-specific kits do not require a transmission controller and use a Constant Pressure Valve Body to eliminate the need for a TV cable — the most common source of...
www.tciauto.com
