gremlinsteve
got a small cooling problem-o seems after sitting for a few years i now have a cooling issue. wasnt there before and now its rearing its ugly head high.
she has a new pump, t-stat (180 dg), hoses, new clutch style fan on it also. just before i set it up for a few years the radiator was gone through. its a stock 26 incher and original to the car.
im now seeing temps raise up to about 180, t stat opens, and the temp at that point slowly climbs upwards of 210. she will climb slowyly to that point while driving and or while at idle. when you shut her down the temps climb to about 220 or so but drop right away to 205 when you crank it up.
new radiator caps on it also. in fact ive tried two new ones from stant.
shes got a mild 500 hp small block in it...but its the same motor thats always been in her. any suggestions?
what i am leaning towards doing at this point is buying one of these ebay 2 core or 3 core aluminum radiators for the car. and make a shroud for it also.
steve
steve
