Here's what I do know: The big block and small block 727 transmissions are the same length. They use the same transmission mount and the same mounting location. The driveshaft is the same length and interchangable. Basically the motor location is determined by the MOTOR mounts which are different. Logic says with the transmission in the same location on both setups, the linkage is the same. I even think I have done the swap before, but I want to make certain before I sell you something you can't use.
Greg Purcell
