rakort
This is everything I got, Close to 90% complete $350, nothing has been cleaned up on these parts. they are as pulled.
The good
Panels/door/chrome pieces look usable
Wire Harness is all there, only one cut yellow wire where I believe it hooks up into the door switch area
Most if not all OE hardware is there
The shifter looks like it will clean up nicely
not sure if it is pictured, the bracket for the tranny is included
The Bad
One tab broken off the console top plate
obviously needs a new plastic housing
the floor mounted brackets at the bottom will need replacement or some metal patching
at least one of the chrome trim pieces need to be replaced (but attachment hardware is there)
probably want to buy a new hinge
The good
The Bad
