pushrod
Will a Ax15 5-spd from a 2 wheel drive v-6 Dakota PU work on a small block? I found one with the bell housing for $250 and thought about putting it in my 67 D-100 behind a mild 360 with a tunnel ram.
The guy says the bellhousing bolts up to a small block. I know it would require a fabbed trans mount and I believe it is the one without the internal throwout bearing. It has .75 pilot shaft, 10 spline 1.125 input shaft. All input appreciated.
