Hilljack68
On an 8 3/4 rear end, are the axle lengths the same for a Sure Grip vs. an open diff?
The early models were longer in a open diff axle but, sometime around 64/65 they standardized the length.On an 8 3/4 rear end, are the axle lengths the same for a Sure Grip vs. an open diff?
1964 and older tapered axle is different. Sure grip same, open is shorter 1/4" per side. So you cannot swap a 1964 and older open third member into a 1965 and newer rear axle.
Made changes to post #4 correct now.
In post #4 I put a cone SG in my 66 open 8.75 and axles were to long as mentioned, why? There is no doubt that it is a 66 rear. It is not the adjuster. I pulled a power lock SG from another rear went right in and adjusted side play no problem.
YesWhether it's a Sure Grip or an open diff, are the shafts the same (between left and right)?.... on a 1973/74
