- 4:35 PM
- Jan 15, 2020
- Okeechobee, Florida
This system is no longer needed. The Meziere 55 GPM (PN# WP316) remote water pump will need a rebuild (Meziere will rebuild this one, it's still current production @ $497.85, so it's worth getting it repaired. Per their website they charge between $100-$150 for this service). All the Meziere AN fittings and some hoses (you will need to see if the hoses will work for you and they are 16+ years old) come with it. It had a low mount for the 1 wire alternator (it's seized from sitting so long and shows corrosion but I left it on to show mounting). Engine 3/8" plate is in great shape, not much to go bad with one. This system has lain idle for 5+ years, so don't expect to just mount and fire up the water pump. $250 + shipping.
Chuck (snook)
Chuck (snook)
