Back Surgery - Laminectomy
Rick62
12:41 AM
Greer, SC
I've had back problems for years. The primary problem I have is spinal stenosis which causes numbness and weakness in my right leg. Stenosis is like carpal tunnel syndrome except it's in the spine. It's been getting progressively worse. My neurosurgeon will do a laminectomy on Tuesday. Basically he will remove a small portion of three vertebrae. I'm interested in hearing from anyone who may have had this procedure. I'm mostly interested in the recovery process. How long does it take? What can I expect?
Sorry i dont have any answers for you Rick, but do hope all goes well and you are pain free and back kicking *** and taking names. Keep us informed on how things go and best of luck
Hi. I work in spine surgery. Who is doing your procedure? What levels specifically? For three levels the procedure should take between 45 min and two hours, depending on exposure depth....etc. Obviously your back will hurt post-op. Your leg pain/numbness/weakness should be gone almost immediately, assuming you have not let this issue fester for years. If you have had prolonged weakness it can take anywhere from a couple days to six months for the weakness to improve. Sometimes never, but that is a worst case scenario.
Rick, wish you the best, and funny you write this post, I too am going to be having a similiar surgery hopefully soon. I have 2 torn discs L5-S1 and L4-L5. I have stenosis also, and the neurosurgeon wants to do a laminectomy and go into spinal canal and trim inside of vertebra. Trick is to find a good neurosurgeon the first guy I saw waffled on me, this was due to piss poor mri and radiologist report. Had a 2nd mri at different place much better quality, radiologist report was a little better. Changed Drs and went to Northwestern University, I thought 1st Dr was good, the guy I'm seeing now is head and shoulders above the first guy. Right now my feet go numb and right calf, and sometimes my feet drop when I go up or down stairs. I'm hoping this takes care of my problem. He did say if I do nothing I will have to wear leg splints to hold my feet up later in life....dont want that. I'm 47 and in good shape, and still have a lot to do in life. But remember the old saying, you can't get chicken salad from chicken ****, so I hope for both of us we still have enough good stuff left in our spines that we will both come out good as new.
Msherma5 thanks for the insight on this.
The neurosurgeon is Dr Gardner here in Greenville, SC. The procedure will be on L3, L4 and L5.
Unfortunately I do not know Dr. Gardner. I am sure all will go well. Speedy recovery!
I had it done two years ago. My operation took 4hours. Aside the pain from the surgery -I was able to stand up straight and the numbness/lack of control I had improved dramatically.
However, I was told that my stenosis would continue as gravity and age are relentless.
This spring I had another bad pain and additional weakness in my left leg. (my clutch leg:eek:). The new MRI shows little room left for the nerves coming out of the spine. This time the doctors said I need a "fusion" --They need to add hardware to jack the vertebrae apart to make more room for the nerves and make bone grafts so they become one. Since I was improving a bit every day I held off doing the fusion.
After prodding the doctors --I was told that damaged nerves can and will heal. That is why my pain went away. The weakness is from atrophy of the muscles and they too will come back with exercise and new nerve connections being generated.
At this point, I am without the pinched nerve pain (that was a 9 or 10 for a couple of weeks) and my strength is improving day by day. I can even drive my 69 hemi 4sp just fine.
Every case is unique and I am just sharing mine. As long as I get better and stronger each day I will pass on the spinal fusion. That is something I would only do if it was needed to keep me out of a wheelchair.
Can't help with your specific procedure, but my Dad went through back surgery for nerve pain this past April with a benign tumor (doc said it was about the size of a large cherry) in the L2/L3 area that was pressing against his nerves, causing significant pain in his legs. He said the pain from the surgery recovery was a little bit more than he expected, but post-op the nerve pain was 100% gone immediately. He was back on his feet in less than 24 hours and 90%+ recovered within 6 weeks. He's an avid golfer and was back on the course without pain by June.
Hoping for a quick recovery!
I had surgery at L4-L5 back in 1998 and again in 2005 (it re-herniated). Herniated disc and laminectomy. I'm fine now. Both times I woke from surgery and was able to get out of the bed and go piss in the bathroom. You're walking that same day, maybe overnight in hospital. No biggie.
Rick, Ski 61, casting Good Vibes You Guys Finish Well!
Pretty much what I had in 2000. And as you stated I was up and moving around with out pain, where before surgery I was flat on my back and in pain all the time. Glad I was at home when it happend. A coworker was coaching a hocky game six hours from home when is disk ruptured. The hard part was getting home as he couldn't lay dow in the vehicle he came home in.
When I had my big pain earlier this year the worst position for pain was flat on my back. The MRI was like having a root canal without novocaine. They said--now hold still for 25 min.:eek: I made 15 min. until my squirming blurred the image and it had to be aborted. Tried again in a couple of days with the same pain and got through it--made a clear image. Damn them sensory nerves.
The pain I experienced prior to surgery was like lightning going down my leg. The sciatic nerve was really irritated. The majority of my pain was in my leg and side of my calf. I never really had a ton of pain in my back. Prior to surgery I tried PT, chiropractor, injection in my spine - nothing made any difference.
If you need the surgery, do it.
I was sore at the incision site, muscles that were cut, but no more leg pain!
Rick - PM me if you would like.
Been there, done it. In 2014, had all 5 Ls (L1 to L5) and S1 done. Took 6.5 hours. I was essentially a cripple for 5 years before. No accident led to my spinal failure, just used up my body over 57 years of being very physical. The surgery was the best thing I have ever done in my whole life. I was immediately pain free (spinal), it was the surgical site that was painful and needed plenty of therapy. I knew at 5 hours after surgery that I was permanently fixed, even in a drugged state I knew in my bones and bare naked consciousness that my spine pain was gone, and then I slept (drugged) most of the next 48 hours.
Recovery was in multiple stages - 5 days in the hospital, first 2 as a complete zombie with the happy drugs, 3 days to adjust and get off the juice, plenty of pain at the incision. They basically sliced my back muscles open about 12 inches by 6 inches. Assisted walking was on day 3, home on day 6, using just ibuprofen then. Lots of attention to wound care. Mobility with a walker for 10 days, then a cane for 14 more. Able to think very clearly by day 7, was working from home at that point. Back to the office by day 14. Taking everything slow and deliberate but pain free and liberated from the years of pain.
Physical therapy was 4 months, about 40 sessions. First 6 were at home, then I could drive to the facility. They taught me how to walk again. I did nothing "normal" physical for about 8 months except long walks and the list of therapeutic exercises (planks, stretching, etc.). By month nine I was running, weight lifting, and lots of hard labor. Always with a serious eye toward proper stance and back muscle health. I would say I had recovered completely by month 12.
Best thing I ever did. It is critical to do all the therapy they give you, and follow all directions, or you could take years to truly recover. Be patient, but do the work of the therapy or it will all be a failure.
Best wishes to you.
Thanks to everyone for their input, advice and concern.
I hope everything works out well and solves all of y'all's back problems!
