reverse lights at the trunk. Work your way back down the driver side of the trunk and the harness will run up and over the rear wheel hump. Then it enters the seating area under a shield on the driver side just under the sill plate. And from there goes into a connector in the driver side kick panel. I would also look under the dash at the switch on the column. Unplug that and see if they go off. Switch could be bad.
