Satellite Pilot
Built a new 440 for the Satellite this summer, fired it up today and ran through break in. All is mostly well, have some issues to work out. The biggest issue i'm struggling with right now is the starter. When we started the motor the starter seemed to be really struggling to turn the motor over but it would eventually fire up. After a few times of starting it would struggle more each time and then we noticed the main ground to the battery was HOT, and I could see a bit of smoke coming from the starter wires themselves. Ok, so there's a bad ground somewhere right? I also need to mention I was using a remote starter switch to crank the engine from under hood. We checked the grounds, cleaned them and then I tried to crank the motor, this time without having the ignition turned on, the starter cranked beautifully, no issues. Turn the ignition on, or try to start with the key and it struggles mightily again. I'm at a loss, hope this all makes sense and hope someone out there can maybe share some insight.
Thanks!
Thanks!
