Coelacanth
- 5:44 AM
- May 10, 2024
- Edmonton, Alberta, Canada
My master cylinder started leaking a few months ago where it bolts to the booster, below the lower 2 bolt holes. Upon removal, I found it's the desireable Bendix unit, so I want to have it rebuilt. The P/N on the bottom shows '22268' but not sure what the last 2 digits are; possibly '24' or '84'...would anyone know? It's from my 1970 Charger 500, 383 Magnum, rear drum/front disk power brakes. The piston diameter is 1-1/8". To my knowledge it's original.
What's baffling me is I can find no way to remove the piston. There is no bolt anywhere on the cylinder body, nor inside the pots. I can see no circlip or anything else retaining the piston inside the bore. What's the magic holding it inside?
The bore looks better than I expected, except for the outermost 1/4" or so. I was quoted $800 CAD to re-sleeve and rebuild it, which seems very excessive...especially when you can buy a complete booster, firewall mount plate and master cylinder assembly for under $300 USD, though the ports are on the fender side instead of the engine side. Looking forward to your advice and thoughts.
