bare metal preservative?
mmissile
7:05 PM
Motown
Looking to coat my cast-iron parts with something to deter rust, but natural looking. Don't want to paint or powder-coat.
Thanks.
You can check this out from Eastwood. I saw it before, but have not tried it...
  • Home
  • Calyx Manifold Coating 3 oz
Item #11171 Brand: Calyx
4.6 out of 5 rating. 4.6
(14)
Rub-in an instant, long-lasting,
cast-iron luster
Details
Rub-in an instant cast-iron luster with easy-to-use Manifold Dressing Your project vehicle's exhaust manifold will look like new after you rub it down with Calyx Manifold Dressing. It's easy to apply and long-lasting.
  • Rub-in with rag or toothbrush
  • No disassembly required
  • Enough for 8-10 typical V8 exhaust manifolds
More info...
About Calyx Manifold Coating 3 oz
Though it's not as durable as our paint on coatings, it is convenient and easy to apply because there's no disassembly required. Just remove loose rust and rub-in thoroughly. Non-toxic and water-soluble. A little goes a long way: one container treats 8-10 typical V8 exhaust manifolds. Made in USA.
Application
For the best results, manifold should be removed, abrasive-blasted, and wiped down with PRE Painting Prep (10041Z) before applying. If you wish to apply Calyx while the manifolds remain installed on the engine, use a wire brush to remove surface rust and dirt, then wipe down with PRE. Apply Calyx with a rag or toothbrush, and work it into the pores of the metal. For a buffed appearance, use a fingernail brush.
Contents
3-oz. container of Calyx Manifold Dressing, with instructions
Accessories
10041Z PRE Painting Prep, Aerosol
MSDS Sheet
Click Here for Material Safety Data Sheet
Customer Reviews
Reviews
Rating Snapshot
5★ stars
10
4★ stars
2
3★ stars
2
2★ stars
0
1★ stars
0
Average Customer Ratings
I use high temp satin clear from vht. Holds up decent if the surface is clean and prepped.
I've been told that liquid graphite is great for exhaust manifolds. Sold at Napa stores.
I'll be needing this for cast-iron suspension pieces. No heat involved.
Not sure if they still carry it, but Eastwood Co. used to sell a product they called Heavy-Duty Anti Rust #2712 for protecting bare metal. It's a spray on type product. Kind of like Cosmoline. Might be something to consider.
I have used "Everbrite" on my aluminum engine with no visual difference of the aluminum surface.
Mike
