PolaraFury
Hello,
I ended up disassembling my 500 stroker to replace the rear main seal. (I got heave handed with sealer and I couldn’t get the upper to come free and push out). The motor only has a couple hundred miles on it.
I found out my #7 rod bearing is toast and I have odd wear on my mains too. I thought I had all my bases covered and apparently I missed something on assembly. Any thoughts?
Thank you
Thank you
