Bench seat removal?
polkat
6:14 AM
Chico, CA
Pulling the bench seats from my '64 4-door Fury. I'm guessing the back bench seat just prys out like on most cars, but where are the anchor nuts removed from the front seat? Under the car (as I suspect)?
What are you going to do with them fellow Californian? :toothy9:
I'm just going to run a single bucket for the driver. They are only in fair condition and the driver's side of the front bench needs some work (springs are exposed a bit).
I'll trade them all for a decent bucket if you know someone who's looking, but I can't ship.
The back bench seat bottom kinda hooks in place so you have to push down and back then lift up. Do it on each side and it should come free. I believe the back has a bolt & nut on each side toward the bottom then would lift up. Hope it helps...
The back bench seat bottom kinda hooks in place so you have to push down and back then lift up. Do it on each side and it should come free. ...
correct on seat cushion, the seat back has two brackets hanging down on each bottom corner. there are metal tabs sticking out of body, just pry them straight out and pull brackets from seat out. then pull seat back straight up to release from hooks on body ....
