where can I get bolt hole dimensions for B,RB blocks? spacing for main cap bolts,oil pan bolts. would like to have the bolt hole dimensions for the both blocks. THANKS
try any of the Chrysler specific historical sites ??????
there are a ton of links on the bottom of this page you could try,
contact someone they may help you
{kind of doubtful from a business aspect thou} http://www.moparts.com/ main index
Just curious, why do you want them? If you are thinking of machining your own caps or girdle, for example, I would think you'd want to confirm your measurements or better yet, take your own measurements from oem pieces.
