BIGBLK_WP27_5 SPEED
440 WITH A QUICK TIME BELL and 1/8" block plate TREMEC TKO 600 Mcleod Street clutch
Can anyone tell me if a stock height pivot bracket with a stock fork should give me the required travel to fully engage the pressure plate. The kit I recieved uses all stock clutch linkage but the quick time pivot bracket supplied with the bell is stock height. The newer quick time pivot brackets are 1/4 inch higher than mine. My bell has narrow bolt spacing and is older about 3 to 4 years.There for, the new quick time brackets will not work on mine because they changed the bolt spacing to stock mopar spacing. The folks at quick time say the 1.80 inch tall bracket is the one I need however, Brewers say 1.550 is stock height. I would rather not keep installing and unistalling brackets laying under my car, until I get it right. I had the 1.550 bracket in the car and couldn't get the 10 1/2" Diaphram Clutch to fully engage. clutch pedal was 4 inches from the floor. I am thinking the block plate requires the to bearing to travel an extra 1/8 and the height of the pivot needs to be longer than stock height. Any one have any experience with this ?
