SOLD Big Block Mopar Performance Aluminum Heads
superstock440
3:31 AM
hedgesville, wv 25427
Feedback: 2 / 0 / 0
Ok, I have a set of mopar performance stage 5 big block aluminum heads. I had the built for a stroker motor I was building. start off, the part number is P-4532134. the heads have been cleaned and checked for cracks and came back ok. I had them shaved down to a 62cc to get more compression. they have been pocket ported to flow more air just on the intake side. flow is around 325cc's. have had new mopar performance stainless valves put in they are 2.15-1.88. the spring's are comp spring's good up to a '700 lift solid roller cam, along with new cups, caps, and retainer's. these are ready to bolt on and go. I was building a 440 stroker to a 512ci. with these heads I was looking around a 14. compression motor. yes I was going racing. I am asking $2,000.00 plus ride. if need to know anything just let me know. thanks
2018050295173956.jpg 2018050295174054.jpg 2018050295174020.jpg 2018050295174148.jpg 2018050295174342.jpg 2018050295174455.jpg
View attachment 601956 View attachment 601957 View attachment 601958 View attachment 601959 View attachment 601960 View attachment 601961
Styandard port ? You said 325 cc , what do they flow ??
Please start a new thread in the appropriate forum for talking about what the heads are....thanks.
do these heads need the spacer plates
On a B block the intake would be a RB or use with spacer plates.
On a RB, there is a set of intakes that would be specific to fit without the spacer plates.
Otherwise spacer plates would be needed with regular RB intakes.
these will work with the b and rb block. just have to get a b intake for a b motor, and a rb intake for a rb motor. you do have to run spacers if you run the heads of a max wedge motor, like the 413 and 426's. you can look on summit and see where it says you can run them on both. thanks
i
f you look the link shows
the link says stage 6 not stage 5
they are stage 6 heads. I hit the wrong button when putting them on here. stage 5's are cast iron heads and stage 6 heads are aluminum heads. i do have a set of spacers to put these on a max wedge motor. I would through them with the heads. here's pic's of them. thanks
