SOLD Big Block Parts
Roscoethug
11:28 PM
Pennsylvania
Feedback: 3 / 0 / 0
383 Short Block. Standard bore with cam, hydraulic lifters and push-rods casting #2468130-7 LL out of a ’69 Roadrunner. Needs rebuild $500
Set 906 heads w/valves, springs, rocker shafts and rockers. (Needs 1 rocker arm). Dates 3/4/69 and 3/14/69.
Also out of the above ’69 Roadrunner. Needs rebuild. $250
1 steering box 16:1 $200
The above parts are from my ’69 Roadrunner and was running when the engine was pulled.
The parts below did not.
1 set 906 heads, dipped and milled .015. Have valves, springs, keepers. Date codes 1298 and 0736, off a 1968 Chrysler 383. $225
1 re-manufactured B distributor (points) $70
1 re-manufactured RB distributor (points) $75
1 set stock valve covers, used but serviceable $80
Take it all away for $1200.
