vegiguy
I'm having a hard time figuring this out even though I have a picture of it in the shop manual. The picture in the manual doesn't give a detailed view of the connections on the water valve itself; also the water valve I have doesn't look like the one in the manual (it doesn't have the "can" on top of the four outlets, and it sits so the outlets are almost lined up vertically on the firewall). Will the type of valve I have work, and if so is the side of the valve that has the smaller (1/2") of the four tubes considered the side of the valve that the coolant goes thru on its way TO the engine, or FROM the engine going back to the heater core? This is on a '73 RR.
Thanks for any help with this.
