It's probably not necessary... But not knowing exactly what your combo actually is... I've had engines with well over 750hp with stock caps & a block girdle & ARP studs, line honed & checked regularly, after each racing season when I would tear the motor down, I never ever broke any, but it was also a very light car too... That's not saying they can't or won't break, or even walk a little, but also even a 4 bolt cap can walk a little, with allot of compression or boost... But also any Billet main cap Steel or Aluminum will need to be Professionally Machined/fitted & bored, by someone who is familiar with that type upgrade, then they will need to be line honed & aftermarket stud type hardware will probably need/recommended to be used... IMHFO a Block girdle kit like the Hughes or MRE Kit like the ones from Mancini Racing shown below & a good High Quality oil pan & Quality High Volume Oil pump & Quality H-Beam rods with quality rod bolts & good bearing & a good Forged steel crank & a good set of forged pistons... IMHFO is probably a way better investment, on most all performance builds... Unless your planning on a blower or turbos or heavy N20 usage or over the 550-650hp ranges & High RPM's with heavy stock type rodsor allot of compression... The Low-Deck B-400 & 383 have stronger main webs, mainly because of the smaller bore in the main caps... A 4 bolt main cap is kind of a pricey upgrade, but if you need it, it's well worth it too... Don't forget the cylinder heads on a BB wedge, they are the biggest choke point & power robbers...
