Mopar-Charger
There is the sound of a dieing whale coming out of the intake area on my 360. It has just started recently.
One of the bolts on my valve cover wiggled loose. Ended up blowing the gasket so I replaced both sides and still there is the sound.
I'm thinking it's coming from the intake - Carb seal? Leaking or not tightened down enough?
Started happening right on start-up. Doesn't change as the car warms up.
Rather than making a new post, there is an oil leaking coming out of the back of my oil pan area. I believe it is coming out of the crank shaft seal? I've heard that sucks and is pretty damn hard to replace. Do you guys know of any ways to temporarily stop/fix this? Or should I just park the grass until I end up rebuilding the engine?
It spits out about two half dollar sized spills after it sits just after being ran.
