Nope. I would not use dynaglass or duroglass for anything. It absorbs moisture just like bondo And at the end of the day. You still have to use filler over the kitty hair. Or duroglass. You will find that you will have less problems with primer sticking to filler. if the metal work is done right. You should not have to use that much filler.
I have to ask if you epoxy primer the car first then do the body work. Do you spray a sealer on it before you do the top coat.so the moisture if any would be trapped in the filler or would it work it's way into the topcoat or would it go thru the epoxy and work on the inner panel.
Yea but he helps to understand how body work is done. You have to over look the cussing.Such a Potty Mouth!
Like runner 68 posted ^^^^ also look over a primed area after dry for pin holes at the areas you have filler.
you will have pin holes that will need a light light skim of glazing putty then blocked again.
I read on the subject of pinholes to "splash a little acetone in the mix to prevent the holes."
Is there any easy to sand spot putty out there? I used that 3M stuff years ago and it was hard to sand. Most of what I'm filling is around the spot weld areas a very thin coat will work. The bigger fill is in the quarter extension.
The 3M stuff is lacquer based and shrinks. Use a 2 part poly. Sands easy and has a long working time.Is there any easy to sand spot putty out there? I used that 3M stuff years ago and it was hard to sand. Most of what I'm filling is around the spot weld areas a very thin coat will work. The bigger fill is in the quarter extension.
