Bolt and nut sizes
Dallasdrifts
8:41 PM
Canada
Hey I'm Building a 67 and for the body it's missing a lot so what common nuts and bolts should I stock up on so I don't make 1000 trips to the bolt store
Most are automotive assembly bolts, for specific applications. Buying them, can be a killer, dollar-wise.
The sizes are all over the place. Have you looked into buying the "kits" that are available from eBay or the regular MOPAR suppliers? Takes some of the work out of a restoration.
I bought my kit from Mr."G's" and everything seems good! You just can't go out and buy the correct "Type"
of fasteners at the hardware stores. The kits won't have the correct head stamps, but will be close enough.
If you want to nit-pick, you can try and find an old Mopar bodyman and ask if he has a "Junk bucket". They usually
have clips, bolts, nuts,barrel clips, etc.Good luck!
