Bolts/Studs for Attaching Valve Covers
Detroit Iron
2:15 PM
Bay Area - California
To be "correct", how should valve covers be attached on an early B-body B engine? When I got my '64 Polara, the heads had studs in all the valve cover mounting holes. Is this correct for early B-bodies? Or, should the studs only be in the corners, and the rest bolts? I think mid '60's engines had this set up.
Thanks for the input.
I thought it was stud in corners and the rest bolts, but I am no expert on it. I have never seen (factory) all studs.
My 1962 polara 361 ci has factory studs (4) and nuts on each cover.
studs in all holes with 1/4-28 nuts. i know my 68 road runner had studs in the corners and bolts in the center. my 69 r/t had bolts all around. the change to using some/or all bolts was probably mid to late '60's.
Studs all the way around Joe Suchy sells a correct kit studs are 1/4-20 into the head and 1/4-28 for the valve cover nuts.
[email protected]
1770-964-4441
