Capt-Culver
What do they do? Are they absolutely needed when converting from drum to disc? Educate me...
I thought even with 4 wheel disc you needed to have a proportioning valve, am I mistaken?A proportioning valve is needed for any car that has disc brakes on the front and drums on the back. The reason is the disk brakes pads are essentially always in contact with the rotors, while the pads for the drums are not in contact. Without a proportioning valve, the front brakes will engage first. The valve enables the rear pads to engage the drums a second before the front pads engage the rotors.
Think back to when you were riding bikes, and rode with your first set of hand brakes. You learned quickly to never just squeeze the front brakes as the rear of the bike would rise up and at best the back of the bike would swing to one side or another and at worst you could flip over. It's the same deal with cars. If you engage the front brakes before the rear, the momentum of the car can cause the rear to swing to the left or right, and that would be bad.
You often hear people saying "I got rid of my valve and everything is fine", but there are people who A: have discs front and back, B: are people with drums front and back, or C: people who haven't had to come to a really sudden stop yet.![]()
You should have one. You always want the rear brakes to engage first, but with all the wheels having the same brakes the valve isn't as important as when you have a disc/drum combo.I thought even with 4 wheel disc you needed to have a proportioning valve, am I mistaken?
I believe a hold-off vale and a proportioning valve are the same thing.Thanks! I have the proportioning valve. I just didn't know if I needed the hold off valve in conjunction with the proportioning valve.
