Anyone have a pic of the brake line routing from the m/c to prop valve then out to each wheel? 72 charger power front disk brakes. I got this in pieces so nothing to go by. Thanks
I'm planning to spend time at my storage this weekend, setting up and moving stuff around to start in on my 73 cowl. If I have time (and can remember), I'l ltry to take some pics of my 72.
Sorry I can't post any pics cuz my 71 is still at the body shop.
I converted 4 whell drums to power disc up front and stock drums in the rear. I purchased the stock 72 front disc/rear drum proportioning/combination/metering valve and pre bent brake lines from inline tube .com. I purchased the prebent brake lines because basically I suck at bending and flaring these things.
Because I purchased the stock style 72 prop valve and pre bent lines everything pretty much bolted right up with minimal work and no guessing on the routing.
Anyway when I got my car back I'll post some pics.
