Brake problem!!!
alfaury
1:12 AM
PUERTO RICO
Hi, i got a lot of problems with my ply sat 71 because i cant repair the brakes. I used manual brake system with disc front and drum rear, i changed everything and i can repair the brakes, the master cylinder charge the rear drum but the calyper nothing, please help me and excuse my english its not very well but i appreciate your help
Sure you got all the air out of the front lines?
Did you change the master cylinder?
Yes i got all air, i change the master cylinder, pads rubber lines that go to the caliper
...and the REAR resevoir is plummed to the FRONT brakes, right?
Did the pistons move when you put new pads on?
...bench bleed the master?
if you got air out and bled the calipers.....hmmm
Could they be stuck/locked? Both???
Are they mounted correctly?
Sliding style?
What spindles did you use?
Help me i need a caliper photo
Hi i got the problem with my brake i think im not install correctly the caliper, i need a photo of a plymouth satellite 71 disc brake to verify if i installed the caliper correctly, please help me!!!!!
Did you use the master cylinder from a 4 wheel drum car for a disc-drum combination? If so, disc brakes require more fluid volume than drums. Your master cylinder should have a large reservior in the front, and a smaller one in the back.
Make sure the bleeder on the caliper is at the top......above the hose.
