70rr-brian
OK, so I have had this issue for 3 years with the RR and have monkeyed with it only once and just never went back to it until today.
The car pulls to the right under braking. Not like OMFG I'm changing lanes uncontrollably but enough to be noticable and requires correction.
1- Replaced all front end components 2 years ago. Tie rods/ball joints/control arm bushing, all bushings etc. The car drive straight as an arrow down the road at any speed.
2- The tire pressure is the same in both front tires. They are the same tires and no uneven wear on them with 8k miles on the car since front end replacement.
3- The brake shoes on the car were brand new when I bought it. They still look brand new for that matter. No uneven wear on any of the shoes.
4-The previous owner put all new brake hoses on the car.
5- The drum surfaces look perfect and are perfectly round.
6- The wheel cylinders do not leak or stick.
7- The brakes have been bled with no change.
8- The self adjusters are connected and behaving as they should.
9- The tension on the wheels when free spinning is the same on each wheel.
So today I decided to monkey with it and do some testing. I did several things but the most telling thing was I loosened/brought in the right shoes a LOT with the adjuster just to see what would happen. When I did that the car now yanks to the left upon inital braking then pulls back to the right.
I am thinking the left wheel cylinder is either not maintaining pressure (although not leaking) or has a different wheel cylinder bore diameter than the right side. The wheel cylinders do not look new but don't look original either. Or the new hoses the previous owner put on are collapsing internally on the left side.
Does this seem like an accurate diagnosis? If not, I am open to advice. I just hate throwing parts at it if I can avoid it.
Thanks,
Brian
Thanks,
Brian
